GRE PSR-600 FCC Approved according to Scanners Unlimited
hoser147
Grand Lake St. Marys Ohio
Im kinda leanin toward trooperdudes attitude on wait and see what everyone thinks. Although fmon gettin 2 of them tells me he is very satisfied with the new GREs. Ive got enough HHs for now. would like to have a digital base................Hoser
DiGiTaLD
Interference
DaveIN said:
I would think that the PSR-600 would be better at resisting nearby electronic RF interference. It has an outside and inside metal case, better grounding, and the board layout of the same "RF circuit" is separated and enclosed to avoid spurious signals. This is not to say it will be as sensitive as the PSR-500 as most of the GRE radios are.
If it's any indication, my 2096 resists interference in the audio circuit from my GSM cell phone a million times better than my 96 does. When I'm at home, I generally keep my cell phone sitting on the window sash not a foot away from the 90° 800 MHz duck on the back of my 2096. The only time I ever hear it transmitting is when the 2096 is stopped on an analog talkgroup, and even then, its only a slight annoyance and doesn't happen that often.
On the other hand, when I'm out in the car and have the 96 on, every single time the cell phone transmits, I can hear every bit of it through the 96's speaker. The 2096 obviously has much better shielding than the 96, probably helped a great deal by it's metal case versus the plastic case of the 96. Owning both radios, I can also attest that the audio quality of the 2096 on it's internal speaker is much better than the 96 on it's internal speaker. Again, this probably has to do with the speaker size and the cabinet it's mounted in. The 2096 sounds a lot more like a professional radio, while the 96 can sound "tinny" at times, and you can always hear the audible hiss at the end of a P25 digital voice decode, something you really have to try to hear on the 2096.
I would expect similar performance out of the 600 over the 500. Of course, if one scanner is all you can afford, the 500 would make better sense because you can take it everywhere with you.
Tom_G
Rocky Hill, CT
And if you like the digital audio on the 96 / 2096 you are gonna love the PSR 500 and 600.
My PSR-500 sounds amazing on digital.
It is a pleasure to listen to.
I initially bought the PSR-500 with the intention of keeping my 2096 in the shack, but after having the PSR for a while now, I WILL be getting PSR-600....
Best of luck.... Tom/G
