Gre PSR-600c
camay123
I was told that it exist a canadian version of the gre psr-600, which would be a psr-600c.
First is that true, if so, what is the difference ?
Forts
Ontario, Canada
I've heard that as well but I've never seen one myself. Perhaps it just has the Canadian band plan setting enabled by default, I don't know. The US version will work just fine here though too.
torontokris
Toronto Canada
Forts is correct (as he normally is) ... just a Canadian band plan.
Should be sold by the Canadian dealers..
VE3SG
Norwich Ontario
Mayby Camay123 can help
I see you also own a PSR-600,I just purchased one to try out.Did you have any problems setting up the OPP,and is there a database anywhere where you can download the South Western region.Any help would be appreciated,I have no problem with the Unidens but this one giving me a problem.Thanks in advance.
Forts
Ontario, Canada
Umm.... You can download the Fleetnet system from this site, if you have programming software and a premium membership. Otherwise just follow the manual programming instructions in the sticky at the top of this forum.
