Get the Whistler update
Whistler company in Arkansas does an AWESOME JOB. ...
Well worth it...
Well worth it...
Did it give the PSR 800 Phase 2?Get the Whistler update
Well worth it...
When I called Whistler,about update,woman said it would put in DMR ,I asked her if it update to phase 2 ,she said No,,I was going to say if update made it a Whistle 1080 which has phase 2,,then it should make psr 800 phase 2,,,but I didnt get the chanceThe PSR-800 was already P25 Phase 2 capable through a firmware update. If you still have the old firmware, the legacy upgrade will update the scanner to P25 Phase 2.
Ok,thats what I figured,,Now last thought,,When the upgrade does all that ,,I have to update the cpu and other things ..from Whistler ?and can I do it on a Chromebook?or it has to be computer? which I have one running Windows 7,,ThanksSounds like the woman at Whistler needs to be retrained. The upgrade definitely will give you P25 Phase 2 even if you still have the Pre-Phase 2 firmware. Your scanner becomes a Whistler WS1080 which is Phase 2 capable. It also adds DMR. It also adds P25 Phase 2 and DMR to the Radio Shack PRO-18 which was P25 Phase 1 only.
Yes, if you want to torture yourself. IMO: a PC is the easiest way and will eliminate keypad errors PLUS a pc ( with internet access) allows you to update the Library weekly. You don't need the latest greatest pc to program.Does the firmware patch make it possible to enter new frequencies without having to hook the thing up to a computer?
