tvengr
Well Known Member
Does anyone know the alternate control channel frequency for the Jasonville site on SAFE-T? Thanks!
The freq next to the CC in the list.Does anyone know the alternate control channel frequency for the Jasonville site on SAFE-T? Thanks!
There is only a single control channel capable frequency shown for the Jasonville site. Linton and Solsberry both show 2 frequencies. Most of the sites on SAFE-T show at least 2 frequencies. I suspect that the second frequency has not been submitted to the database yet.
The 3 sites in Greene County all show site NAC's. It seems unusual the Jasonville site doesn't show an alternate control channel frequency. Thank you!I was looking thru my data and submissions, I don't see it in my db yet, but I have one more place to look. It's likely 853.725(?)... whatever the VC frequency is that is next to the CC. Nearly all of the original sites use the highest two freqs per tower as the CC and ACC.
Where are you located? Are you talking about Jasonville Indiana?Hopefully, someone local will be able to supply that info. Thanks for your help!
Thats where i live, Linton Indiana, Greene County, i just received my new SDS100 & I'm also having some issues that i can not figure out.I am in Maryland, just a little too far away to check the site myself. I am checking to be able to help someone else programming a scanner in Greene County Indiana.
Thank you very much!(1-034) Jasonville: CC- 853.8875 , aCC- 853.3875 , aCC- 853.7250
What issues are you having? A number of the Greene County conventional frequencies use NXDN. Do you have the NXDN upgrade for your scanner? Greene County also uses the SAFE-T statewide P25 trunked system. I would be happy to create a favorites list for you so you can see how it is done. Have you downloaded and installed the free Uniden Sentinel programming software? http://info.uniden.com/UnidenMan4/BCDx36HPSentinelThats where i live, Linton Indiana, Greene County, i just received my new SDS100 & I'm also having some issues that i can not figure out.
