It sounds like you have it programed as conventional frequinces, instead of trunked.
You're right, read the manual and
http://wiki.radioreference.com/index.php/Programming_Shortcut_Pro-96
This is some items from that link.
Pro-96 Cheat Sheet
If system is Motorola Type II start with Programming section.
Storing known trunked frequencies
1. Press MANual, Press three digits to get the bank and channel number desired then Press
MANual again. (Upper left should read Mxxx for your bank and channel number)
2. Press PGM, (upper left should change from M to P)
3. Press TRUNK
4. Press MODE unitl Motorola is displayed.
5. Press PGM
6. Enter the frequency
7. Press Enter
8. Repeat steps 5 through 8 until all frequencies are entered in selected bank.
Motorola requires only the control channels entered.
Storing known Talkgroup ID’s
1. Press PGM
2. Press TRUNK
3. Enter the 5 digit Mot or 4 digit ED ID
4. Press ENTER
5. Press Up button
6. Repeat steps 3, 4 and 5 until all are entered.
Storing known Text Tags
1. Press Manual, Press three digits to get the bank and channel number desired then Press
Manual again. (upper left should read Mxxx for your bank and channel number)
3. Press Text, the cursor appears on line 3.
4. Using the numbered keys text in the line up to 12 characters. The letters above each number
will help in the selection. Example, POLICE DISP (11 characters counting the space)
The first letter is P, Press the number 7 then the number 1 for P. (7 will open the four
numbers PQRS and by selecting 1 is for the first of these four. A 7 then 2 would get the
letter Q. Presses up or down to move the courser back and fourth or to correct a mistake.
5. Press Enter
Scanning Banks
Turn Radio on, the last bank(s) selected will start scanning.
Note: If the radio was in search mode when turned off, the radio will continue that search
pattern when turned on until Scan or manual is pressed.
To change scanning banks.
1. Press the number associated with desired bank. The number on top line of display will
either be on or off accordingly.
To change from Open Mode to Closed Mode (or the reverse).
1. Press FUNC + 5 (Bank Open or Bank Closed will display).
Note: The scanner will not stop on any TG id’s which are Locked-Out, OPEN or CLOSED modes.
In OPEN mode, all others will be scanned and CLOSED mode only stored (see below) unlocked
id’s will be scanned.
Talk Group ID’s
These are Identification assigned by the manager of the system you desire to scan.
Storing unknown ID’s
When the scanner stops on a conversion, Press Trunk, the bottom line will indicate where
the ID is saved as x-xx, where the first x is the sub-bank number in the bank and the xx
is the the location position in the sub-bank, number 00 to 29.
Note:
1. Each bank has five 30 ID positions for a total of 150 per bank.
2. If an ID was already stored, the bottom line will display ID was saved.
Storing Known Type II or EDACS ID’s
1. Select out all banks except desired bank ie. While scanning press each numbered bank to
deselect it except your desired bank.
2. Press PGM.
3. Press Trunk.
4. Press down until bank 0-0 appears at the top with Id no. 00 on the second line.
5. Press mode, if needed for MOT or ED.
6. Enter the ID number, if necessary use the period for a hyphen. Entry will be on line three.
Note: Pressing TEXT after each ID entry will place the prompt on line three
again for keyboard text entries.
(During scan, these text tags will appear on line four)
7. Press Enter.
8. Press up and repeat 6, 7 and 8 until all are entered.
Motorola Fleetmaps
NON APCO 25 (9600-Baud) Motorola Systems use a fleetmap to help determine Talk Group
information. The most common system is an all Type II, which is the default system on
the Pro-96 and therefore requires no special effort on your part.
This document by Frank Monroe with grateful help from Lou Maag......................and really edited by Grog
