Hello:
This is confusing me to no end: grounding the shield. I just received my tech license and thought I'd have a go at 10 meters. The Antron 99 is supposedly a decent antenna for just such an exercise. I happen to have one in the garage that's collecting dust.
Some say to use radials, some say don't bother. I've also read where some say to simply lay them out at the bottom of the antenna, and some say to lay them out and ground them at the shield. This is a concept that has befuddled me for some time. If I consider what it means to ground at the shield, that would imply that I would need to strip the coax and use the braid in some fashion and connect it to the radials. This doesn't seem logical. So then, in laymen's terms, what does grounding the shield actually mean?
The best I can come up with is that one leaves the coax intact and uses a ground block. Certainly I wouldn't strip cable for this endeavor...
Thanks for your patience.
