Grundy Co Starcom
RoninJoliet
ILL
Today on SCom hearing 100 and 700 cars on TG2430 and FD on F1-No....Thanks for your replys....
MikeyC
Utica, IL
I ran Pro96Com against T113 (Will County) for a bit last week as I passed through and it looks like Grundy County Police 2 (2430) is running in Phase II on T113 at least. Haven't seen any Phase II on T125 (Morris) at all. In fact it still reports as a "Phase 1" tower.
RoninJoliet
ILL
I heard the "analog " system still has the SHF on it as they have not changed over as yet...I still hear T125 also ....Last week when some of the EMA were testing there new radios both my 996P2 and 325P2 read out "PTO-PT1" when they keyed up instead of P25 and that was PHASEII...Now lately I have not seen that on the FD-Morris and Minooka, GE and the Mini Bus....
RoninJoliet
ILL
I guess I spoke too soon I have "NO" CC on T125, it may be shut off now for use by T113....
nick223
Ottawa Illinois
the last few days it seems like everything on the Morris tower is now on the Ottawa tower now. Wescom, Isp D21 Tgs ect..
RoninJoliet
ILL
Nothing still on Morris tower but I now do hear the Grundy Sheriff on the "analog " system with (3) bars being a distance away so things must not be fully functional yet....Was a heck of a band opening early this morning and was hearing "Towers" all over Las, Bur, Rockford and Kank but closed up about 9am.....
MikeyC
Utica, IL
T125 shows up as "failed" for its neighbors. T113 is coming in full strength in Pro96Com inside a building in Morris so it looks like the move has been made.
On a side note it's as strong a signal to the west as the 800 MHz channels were. I used to be able to pick up T125 from around MM 97 on I-80 but didn't get much of a signal this morning on T113 until around MM 105. The Seneca tower, however, should "fix" that
nick223
Ottawa Illinois
T125 had great signal in Ottawa. Hopefully when the Seneca tower gets turned on we will be able to hear that in Ottawa.
MikeyC
Utica, IL
Forgot to mention -
The analog system is still on the air. Fire North is patched to Fire 1 on StarCom. Police 2 is using Phase II and Fire 1 is using Phase 1
RoninJoliet
ILL
Your correct I'm seeing "PTO/PT1 all day on TG2430 , on the 996P2 , gonna have to just listen maybe to the "FD" on my RS197s.....
RoninJoliet
ILL
Was in Morris today, someone was using TG36016 on PhaseII and "ENC"....
MikeyC
Utica, IL
So is the Morris tower 125 now a T113 so i can delete the morris 800 freqs?
It looks like it.
It does make me wonder if this will affect Ameren ops at all? I used to log them on T125 when passing through so some radios were affiliating with them.
Jake68111
Morris, IL. (Grundy County)
I've deleted the Morris Tower Freqs from any of my saved lists but likewise......
If/when this Seneca Tower gets fired up as suspected, I might stand to gain TG's if its going to cover any of LaSalle County. I've been able to receive very few digital or analog signals from out that way. I've gained quite a bit of TG's on this new Will/Grundy Tower as the signal is quite a bit more powerful than it used to be. Although I've noticed my 800 is having a hard time receiving some Grundy TG's. Might be a decode issue as I can partially make out whats being said and the rest is garbled. Very intermittent issue.
Is there a timeline on that Seneca Tower?
Ummm, there.... is.... a .... proposed Seneca Tower, right?!?!?
nick223
Ottawa Illinois
Seneca is now using starcom. I don’t think their towers up yet though. I’m told they have full signal in tower on their radios that they never had before when this project first started. I’m assuming they are just picking up the Morris site.
