GTX800 Analog?
emanuel32804
Hi all,
I'm looking at getting some gtx800 radios to use in a mmdvm repeater. I see they can do conventional non-trunked, but are they able to do just regular, plain old analog? Does that still work if its in talkaround? The goal is to have the mmdvm output P25 into the radio and it would just transmit it as analog. It seems most mmdvm boards have trouble outputting analog, which would allow the radio to output P25. The other thing that I'm trying to figure out is the accessory port pinout.
Pin NumberDescription
1External Speaker-
2External Mic Audio
3External PTT
4External Alarm
5Flat TX Audio
6SCI Data In
7Ground
8SCI Data Out
9Emergency Switch
10Ignition (+12V to turn on radio)
11Flat RX Audio
12General Purpose I/O
13Internal Speaker or Ground or Sw +12V (see below)
14Hook Switch
15RSSI Buffered
16External Speaker+
I see TX audio, RX audio, and PTT but I don't see any kind of RX indicator unless it's not something that would be obvious. Maybe GPIO or hook switch? Any thoughts?
Of course, if there is a different radio that can do 800mhz that you all think would be more suitable and accessible (cheap too!), feel free to suggest it.
Thanks,
E
emanuel32804
Is there any additional configuration that has to be done though? I know in XTS radios for example, you select non-astro in the conventional personality.
