Balanced audio out
otobmark
NC
VP8000 has speaker +/- audio and i'm sure tying to ground would do damage. Lately I've been building cables for data boxes (tnc) and some other remote audio gear. I had several rugged radio headsets I used for racing which had Kenwood adapter cables (Used with TK390's originally). I was going to use them with my VP8000 until I remembered the balanced audio (unlike my APX radios). I opened up the connector (14pin side connector) and to my surprise I found a PCB. It "seems" to do transistor PTT, pad MSW/SSW pins and isolate the balanced audio out. Uploaded image of PCB to AI and it also identified the same functions. Question is should I trust it? I don't think of rugged radio as a upper tier vendor though they are popular headset among professional race teams. I have only done ohm meter probing which indicated that the functions I mentioned had no direct path to ground. Maybe I'm paranoid because I seem to recall a post about a dealer blowing up a VP8000 with a RSM--an OTTO I think, which is a very high end RSM.
I'm used to balanced audio since my commercial HF radios all have it (and Harris Mil gear) and I use isolation transformers to connect to unbalanced audio. If the rugged radio adapter cable is solid, they would be a relatively cheap and certainly convenient donor for my gear. Any ideas about any of this or alternate strategies?
jeepsandradios
East of the Mississippi
Does Kenwood sell an adapter already ? May check around for commercial products already out there. Over the years I've used David Clark, Rugged Radio, Racing Electronis, and a few other not name brand and most had radio specific cables. Alot of companies will make custom cables if you know what you need.
otobmark
NC
Well Rugged no longer lists cables for 14 pin kenwood/viking radios (or 12pin motorola). I can find no headset manufacturer that mentions the balanced audio situation or transistor PTT. Some may do it but not mentioned on their websites. When I see all the companies offering RSM and headsets for these kenwood radios I wonder if it is russian roulette everytime you use one? I notice in my KMC70 RSM there is no circuitry in the connector itself but given the cable is 14 wire I suppose all the circuitry is in the actual mic. Until now I’ve really been reckless concerning audio connections on my Kenwoods and wonder why I haven’t blown something up before?
