HAARP
ai8o
Brachiating Tetrapod
Lexington, NC
Where is the HAARP facility?
I don't need a street address, just general location.
Dan
AI8O
iMONITOR
Silent Key
S.E. Michigan
HAARP Research Facility :alien::cool:
11.3 mile, Tok Cutoff, Gakona, AK 99586
krokus
Southeastern Michigan
Dan
AI8O
According to many conspiracy theorists, my former duty station is "one of them"... (It is not, but is a VLF transmitter site, with HF capabilities, too.)
dlwtrunked
None of the current *CONUS* USN VLF (under 30 kHz by ITU definition) sites (ME/ND/WA) have HF (Cutler shut down its HF years ago). But Dixon CA USN does have HF and LF (30-300 kHz, sometimes on 55.5 kHz). I have been to all 3 of them. The only HAARP location (ignoring conspiracy theories) is Alaska but there are of course similar other locations.
nd5y
Wichita Falls, TX
For some reason the tin foil hat people seem to ignore the other similar facilities around the world.
I worked at the former NAVSPASUR main transmitter (33.547, -98.763) back when the Navy ran it.
littona
Super Freq
Council Bluffs, IA
At Galena, we maintained a system similar to WSPR for MITRE. It was a PC connected to a Pacer Bounce transceiver that would send and receive data on different frequencies, checking for propagation. It probably assisted with turning on the Northern Lights as well. :D :D
nd5y
Wichita Falls, TX
There is only one HAARP that I know of. There are several other upper atmosphere research radars and space object tracking radars. I don't know the total number. Here are the ones I know of off hand. There are probably lots of others and others that are stricly for military use.
located at 69.298, 16.043
locations are at the bottom of the page
The NAVSPASUR "space fence" where I worked for a short time 30 years ago was eventually shut down and replaced with
The Air Force (now Space Force) also has which supposedly could do everything the old NAVSPASUR could do and do it better because it has a steerable beam at 440 MHz instead of 217 MHz.
krokus
The site I mentioned is IO; the HF was for fleet support, and shore site connectivity.
