Halton Region Unknown TG
mbstone99
Hamilton, Ontario
Anyone have any idea what TG 1500 on the Halton system is? I have seen a could RID's pop up on this TG but none of the other RID's I have seen on the Halton system are in the same range.
Last seen today was RID 92800, 92802, 92850 & last seen back when I lasted checked back on Jan 7th/26, RID 92805.
Matt
Enjoi19
Ontario, Canada
All the radio IDs logged on that talkgroup are associated as well with TG 100 - 1 Dist for HRPS.
mbstone99
Hamilton, Ontario
Any idea on whether its clear or ENC? the 92xxx looks like Oakville Fire. Could be an interop TG?
I went through my logs and don't see any encryption being used.
Hmm then maybe then this is some type of interop TG.
Matt
Enjoi19
Ontario, Canada
I'm not sure honestly - I have zero activity from them on any fire TGs and while the 92xxx does fall into the fire section, the next 8xx digits are far from anything fire uses. Other 92xxx IDs exist on the water treatment TG too. So I'm not overtly inclined to label it as interop yet. Will keep monitoring.
pokey
Is there any patterns as to when this TG appears to be in use?
mbstone99
Hamilton, Ontario
I went through my logs and don't see any pattern to it's usage. But it's hard to tell too with all the other traffic on the system going on at the same time as well.
Matt
