fineshot1
Don't know about the chimney mount but you would ground it
to a ground rod(about 3 feet long or more) pounded into the ground
at least 3 feet away from your foundation via a heavy gage wire,
usually at least a 10 or 8 gage wire. The wire should be clamped
to the bottom of the mast and routed to the ground rod in as straight
and short of a run as possible.
Also would be prudent to have a lightning arrestor inline of your antenna
cable and that should also be grounded to the rod or a suitable ground
point. If you were to pick up a copy of the ARRL Antenna handbook
there is an abundance of grounding info regarding antenna grounding
techniques or google it on your browser as i am sure there is plenty of
info on the internet.
