I made a stealth flagpole HF antenna from a low cost flagpole kit from amazon and it is working great so I thought it would be good to share.
The kit I used was called: Wevalor 20FT Sectional and what's unique about this kit is it uses swage sections that fit together without using plastic sleeves so it is easy to make the whole thing have continuity. I simply used auto hose clamps at each section to make the electrical connection. The kit came with 5 sections but I ended up using just 4. It is mounted on top of a SCH 40 steel pipe with PVC used to isolate the top from the steel pipe base. 3 radials each for 40, ,30, 20, 10 meters for a total of 12 radials. Each group of 3 was cut to 1/4 wave for each of the bands and slotted just under the surface of the front yard.
Amazed at how well it has been receiving and from what I see by using FT8 and pskreporter it gets out well on 30, 20, 15 and 10. I have to use a loading coil for 40 but have not used it enough yet to get a feel for how it does on 40.
Can provide more construction detail if anyone is interested.
Ended up being a fun project and now I have a nice looking stealth HF antenna in the front yard away from the power poll/line RFI problem I have in the back yard.
