Harris Extreme Mic Question
lbd1123
Does anyone know if the Harris Extreme speaker mic is compatible with an XL-200P with firmware R10D08? If it isn't compatible would the Mic not work at all or would just the basic functions work?
W4EHS
Grant, FL
Mine works with my XL200P, I will say that unless you have a fire strap I would not carry the mic as it is huge and VERY VERY heavy. You could use the mike as a weapon, it is that heavy and that large. It has to be the heaviest speaker mic currently out on the market.
lbd1123
What firmware to do you have? The one I ordered is missing the clip I'm going to try take the clip from a REVO mic that I have to see if it will work..
radiocrazy123
the mic will not work on a XL-200P unless it has R14 or higher firmware.
Also R17C is NOT the most current as of today's date.
and, the mics without clips coming from China are not Harris certified Extreme mics. Take that and read between the lines on what I just said, I won't say any further.
lbd1123
Thanks going to find a dealer for the current RPM my RPM version I have isn't the most current
