Harris NAS
MissouriSirens
St. Louis, MO
Hello Harris owners.
I was told that Harris radios can do “true” non affiliate scanning. Is this true or am I being lied to?
If it can, how good are harris mobiles on simulcast systems?
Thanks!
MissouriSirens
MissouriSirens
St. Louis, MO
It can, tell its transmitter to shut up and it obeys.
Perfect! I recently obtained an XG75M from a friend of mine who didn’t need it anymore.
I do have software so that is not a problem, It seems to me that all I have to do is set the site registration to “never”
Thanks again! Have a good night
K2NEC
5F6
Also make sure to uncheck transmit and calls in the group set
TDR-94
You don’t NAS with a Harris.
Very true. The "NAS" term resulted from programming procedures to "trick" MOTOROLA radios into not registering and affiliating on a trunked radio system.L3H radios "can" just be programned (by design) to not register and affiliate and just passively monitor.There is no NAS programming "trick" for them, but mentioning that the "NAS" term only applies to MOTOTOLA radios has resulted in a hissy fit about confusing people.As if the incorrect use of the "NAS" term hasn't resulted in confusion.....
MissouriSirens
St. Louis, MO
Ah my apologies, I guess I should just say passive scanning instead.
I appreciate the input! Have a great night everyone.
AES-256-Encryption
"Be the change we need"
39A71
Not true. A system admin friend of mine got a correctly NAS whatever you call it XG100 to TX data to a CC. Now, he told me he is unsure of why the radio did it, but he said GW showed the RID. He being on NAS talk group, the Radio would key up for a split second then bonk. This is unknown to the both of us, but the system sees it as a UNAFFILIATION... So no. It sometimes wont obey. Just be careful. Mileage may very... I personally use a BKR KNG P800.
merlin
DN32su
He didn't program it for RX only. When the radio tried to affiliate, it was denied by the system.
merlin
DN32su
He has done this for a little over 10 years... I assure you, everything was triple checked.
I have done this for well over 10 years and I do make boo boos now and then, even tripple checking.
Now if it is all set up correctly, no way the radio will ever try to affiliate, it just won't happen.
