I have been decoding my county's Motorola Type II SmartZone system with OP25 for the past year. The county will be switching to a new system, Harris P25ip, next week. Is OP25 capable of decoding this system?
So, I have started a new instance of OP25 multi_rx.py using tk_p25.py. OP25 scans the 5 frequencies that are listed for this system, but doesn’t lock onto a control channel. Also, I have no system information showing at the top of OP25 terminal. Am I using the correct files for this system? My signal should be good, because I have no problems decoding the old system that is on the same sites.
Yes, I believe they do. You'll have to list all the possible control channel frequencies in the trunking section of the config file and it may take some time to cycle through each freq until it finds the CC
