Harris Unity XG-100 Astro P25 Receive ONLY!
K9OY
On the Unity XG-100P HT, how do you program a channel frequency in the P25 Astro
mode, that's NOT in the MIXED receive mode? I do NOT want to hear any
Analog transmissions, only transmissions that are P25 Astro in nature. Thanks
Forts
Ontario, Canada
Correct. And while it seems odd, you will notice that a PL tone (RX CG in their lingo) is set on a digital channel. This will silence the analog side of things so you should only hear P25.
Echo4Thirty
Colorado Springs, CO
They didnt fix this until RPM2. P25 conventional channels are always mixed mode RX. I just do as the poster above did and set a PL/DPL that I know is incorrect.
K9OY
Yes, thanks. I actually figured this out on my own about 5 minutes after I created this post late last night when I took the time to read the"HELP" file for the 3 Sq Mode: settings. There was a notation in that Help txt that said to enter a freq in the RX CG: box to disable
the analog receive.
Mixed up because in the Motorola Programing world, the choices are Analog, Mixed Mode or ASTRO for RX.
Thanks for your help, again......
Gregory
K9OYise-sirs......
