Harris XG-75M "Warning! Lost MRU"
Trooper78
TN
Hello, I have a Harris XG-75M, which has been working great with no problems for months now. Saturday morning turned it on, and got the " Warning! Lost MRU " on the control head. I tried a different control head, same thing. I can read the radio, but it fusses when I try to write to it. Not sure of what is going on. Any suggestions ? Thanks
Mattsenft
Harrisburg, PA
If it is a remote mount radio, try a different CAN cable. Make sure you have a CAN terminator on at least one CAN port with a remote or dash mount radio. Also if it doesn't have the latest control head firmware you could try to update that, as Harris has resolved a few issues with the CAN bus in the past CH-721 firmware release.
Trooper78
TN
It is a remote mount, but the cable is brand new. And it was terminated. How do I go about updating the firmware. I bought the radio on ebay. It was working just fine, then it decided not to.
ElroyJetson
What was the feature package in it? Just asking because I've got like 50 of them with P25 Phase 1 trunking and you could probably get one from me so cheaply that you might prefer to do that rather than try to recover yours.
Trooper78
TN
It had phase 1 and 2....if I could recover it, that would be great.
rescue161
KE4FHH
Hubert, NC
Lost MRU means that the Main Radio Unit is not talking to the control head. Check the power on the main radio. Typically, the control head will have power to display the message, so I'd check the fuse on the main unit.
Trooper78
TN
Yeah, I checked both fuses. They are both good. Connections are all good, the CAN cable is new. Voltage to head and radio are good.
rescue161
KE4FHH
Hubert, NC
Is the CAN terminator still in place? If it is missing or bad, that will cause the same problem.
Trooper78
TN
Yeah, I think I tried a different one, but, unsure at the moment. I am actually at the NICU, currently. My son was born on the 4th, and he has breathing problems. As soon as I can, I will recheck that.
Trooper78
TN
OK, so I tried a bunch of different terminators, no luck. I converted it to a dash mount, and it still shows Lost MRU on the screen. It also keeps booting, over and over. Any help to recover it, would be greatly appreciated.
prcguy
Did you diddle the bits on the control head with a terminal emulator and make it a dash mount? If so and if it still doesn't work its probably a broken radio.
towersites
Denver, CO
It has been programmed with an uncappable version of flash code. I made that mistake once.
towersites
Denver, CO
The XG75 radios are more sensitive and less forgiving than older M7300 radios. The version of RPM has to Match the Firmware range.
I was able to recover by programming a later version of firmware.
Trooper78
TN
I have RPM 14C05. Would you have a copy of the latest firmware, that you would be willing to share. I would greatly appreciate it.
Radio_Lab_MIA
Four fuses by the connectors on the PK board tend to blow when the DB44 DB9 is removed hot. They are tiny surface mounts, three one-amp fuses, and one three-amp fuse. I repair these all the time on the XG75. The three-amp fuse is behind the cables. Check these first for lost MRU. I can guide you in troubleshooting if that is not the issue.
