So I'm trying to build a programming cable for the XG-75P from an old speaker mic per this diagram, and for some reason it's not working. When I attempt to read the radio, the light at the top flashes red numerous times, but I keep getting the failure to initialize error in RPM, as well as Radio Maintenance.
In the above diagram, should the colors on the left side correspond to the colors on the speaker mic cable? Or, will I need to cut into the UDC assembly itself, and re-solder new wires based on the above diagram?
Also, what am I supposed to do with the Red wire on the speaker mic? I obviously don't have a Max233A module, is this absolutely required? Or is it possible to build something with just an older speaker mic and DB-9 serial cable?
