Harris XG-75P programming cable
merlin
DN32su
Does anyone have a line for an economical XG-75P programming cable ?
Specifically part number CA023407-001
One would think for all the portables in the wild, this cable would be an easy find.
TNX
adamr368
NJ
Is that cable usable on the XG-15?
Yes, 15, 25, 75 - also looking for one, but obviously merlin is #1 in the queue. Doesn't seem like it would be impossible to make, but believe there is an IC that's hard to source (it's been a while) in order to cobble one together.
BMDaug
I am licensed…
Central Colorado, USA
Damn, if there is an IC, that really sucks! I’m happily programming and key loading P7100s with great success… there is a big lump in the programming and keyloading cables, so definitely some electronics involved in making that happen, but I have seven VHF P25C/AES256 P7100s and they work like gangbusters on my IG pool freqs. That’s 11 Harris radios all working to keep my comms private!
A 3D printer may be the answer here… not what you want to hear, but someone has made and is selling a 3D printed accessory for the 100P and it’s pretty reliable fwiw…
-B
adamr368
NJ
From the help section of RPM under "Programming the Radio" is the serial pinout for the P7300/XG-75p.
From the help section of RPM under "Programming the Radio" is the serial pinout for the Unity Portable/XG-15P. This should be a simple cable to make using an old speaker mic if it will also work for the XG-75P.
wa8pyr
Lead Database Admin
Ohio
Ok from looking at a picture of one, doesn't appear to have an IC, just USB. $200.0 new
That's an XL programming cable, not an XG or P7100.
adamr368
NJ
Makes me wonder if one of these couldn't just interface to a properly wired speaker/mic connector fairly easily:
Specifically, this one @ 5v (adding a 5v regulator as well):
New! A232DBCT same as the above but it includes the CTS/RTS lines. Available as a 5v module ( A232DBHCT ) or a 3.3v module (A232DBHCT3V). The modules include a plastic DB9 hood kit. Pinouts on the board are V+,GND,CTS,RTS, TX and RX
natedawg1604
Colorado
So I'm trying to build a programming cable for the XG-75P from an old speaker mic per this diagram, and for some reason it's not working. When I attempt to read the radio, the light at the top flashes red numerous times, but I keep getting the failure to initialize error in RPM, as well as Radio Maintenance.
In the above diagram, should the colors on the left side correspond to the colors on the speaker mic cable? Or, will I need to cut into the UDC assembly itself, and re-solder new wires based on the above diagram?
Also, what am I supposed to do with the Red wire on the speaker mic? I obviously don't have a Max233A module, is this absolutely required? Or is it possible to build something with just an older speaker mic and DB-9 serial cable?
natedawg1604
Colorado
EDIT: After further research I have confirmed you absolutely cannot build a XG-75P programming cable with a speaker mic, the pin layout is different. Furthermore, you apparently have to have a RS232/TTL line converter inline. I guess that's why these cables are so dang expensive, and cannot be found used on Fleabay or anywhere else.
I did find a pretty cheap RS232/TTL converter, however I would still need a connector for the radio with the correct pin layout. Seems like that would be pretty difficult to fabricate yourself.
TDR-94
Yes, they require a TTL converter, in line. Only the XG-100P and XL portables use just a direct USB cable.
