G7RUX
- Joined
- Jul 14, 2021
- Messages
- 530
Afternoon all.
I have spotted something in VHF airband which I do not understand so I was wondering if anyone else here in the UK (SE) has noticed this too, or can confirm what I am seeing.
First let me explain that here in the UK, and across much of Europe there is a rearrangement of VHF airband into an 8.33 kHz channel bandwidth and raster to increase the capacity available in a congested band with busy airspace.
This has led to a lot of confusion since the "channel names" look like frequencies:
Controller says: Actual frequency to set on receiver:
118.005 118.0000
118.010 118.0083
118.015 118.0166
118.030 118.0250
118.035 118.0333
118.040 118.0416
118.055 118.0500
118.060 118.0583
118.065 118.0666
118.080 118.0750
118.085 118.0833
118.090 118.0916
This means that if the controller says "118.025" then they mean the old channel on that frequency with a 25 kHz spacing and chaannel width whereas if they say "118.030" then this means a *frequency* of 118.025 MHz with a width and spacing of 8.33 kHz.
On and off for a number of years I have been listening to VHF airband radio. Where I am usually found we are fortunate to have quite busy airspace and a number of rather busy commercial airports as well as a good number of smaller airfields to choose from. Among these are the famously small airports of Gatwick and Heathrow.
I believe I may have spotted an issue with one of the transmitters at Gatwick. In particular, Gatwick Director on 118.950 MHz. When listening to this I noticed it seemed to be off-frequency (whislting) and using a spectrum analyser I noted that it appeared to be pretty much spot on 118.955 MHz but this does not fit with any of the listings I can find. Indeed when aircraft transmissions are received they are on 118.950 MHz and the responses come 5 kHz high.
Doubting myself, as all decent engineers would, I decided to look closer to see if it seemed that I was hearing a *channel* of 118.960 which would be on a *frequency* of 118.9583 MHz but it appears not to be the case...it is on .955 as close as I can measure with a (calibrated, high-quality professional unit) spectrum anayser.
My suspicion is that someone has been given a configuration sheet saying a *channel* of 118.955 which would be an 8.33 kHz channel width centred on a frequency of 118.950 MHz; what I am seeing definitely looks like an 8.33 kHz channel width although NATS EAD documentation does NOT indicate that it should be an 8.33 kHz channel.
Interestingly I do also see 118.950 MHz signals but there are only three locations in the allocations: EGKK and EGTT, both associated with Gatwick and EGOQ associated with Mona in North Wales (Anglesey) so I am really quite confused.
It is my intention to spend a little while this evening listening to eaxch to see if I can identify their sources from what they give as their calls.
Tra confusedly,
Piggly
I am perplexed so hopefully someone can help me.
118.005 118.0000
118.010 118.0083
118.015 118.0166
118.030 118.0250
118.035 118.0333
118.040 118.0416
118.055 118.0500
118.060 118.0583
118.065 118.0666
118.080 118.0750
118.085 118.0833
118.090 118.0916
Tra confusedly,
Piggly
