Have to remove battery to fix programming cable not connected.
CollinsURG
North Carolina
Is there some other method to get the pager to connect to the PC when the connection fails, other than removing the battery and reinstalling it?
Should have said I tried that. I do have a USB C port I could try.
Probably hard to find a cable to go from USB C to the pagers port.
Have you had this problem?
Yes, just tonight, I made several changes and updates to changes, I swapped USB port twice and both times it worked fine after I switched. Only other suggestion is to reinstall the driver when it happens, make sure you remove the cable from the computer before reinstalling driver.
CollinsURG
North Carolina
I had reinstalled the drive first time. But had to remove the battery. I have a USB C to USB A female cable I can use. At least it isn't just my pager. Thx
