NORCAL
I’m looking for someone who has successfully installed and operated the ARC-XT Pro Software with the USB-1 cable interface to a Windows OS 7 laptop. The laptop has three (3) USB Comm ports. It does not have a RS 232 connection. With BUTEL assistance I got the correct driver for the USB-1 cable (v3.4.36.247 dated 7/26/2012). According BUTEL, this driver supports both XP and Windows 7 OS’s and proven to work. My laptop device manager recognizes the USB-1 cable and says it operating properly. But when I connect the laptop to my UNIDEN BCD996XT via the USB-1 cable and attempt to download systems loaded on the scanner using the Main Menu command (Download from Scanner), I get the message "Serial port is not available or used by other software." There nothing plug into the port other than the USB-1 cable. I get the same response using the other USB ports. I have asked for further assistance from BUTEL but have not heard back from them as yet. The only option to check Communication Setup from the ARC-XT Pro Top Menu is using a RS232 Setup connection/verification. The operator's manual provided on the CD Rom does not specifically address a USB-1 test/setup process, or if something on the scanner has to be re-configured differently using a USB-1 cable. If anyone has had similar experience and knows how to correct the above problem, please comment.
