having swr issues.
Wsak418
I have 50' of lmr400 from preamp to jpole antenna. When testing swr should I put the meter on the antenna end or closer to the radio? Getting different results. Or between radio and preamp? All 3 are having way different readings.
nokones
Sun City West, AZ
If you put the meter between the radio and antenna transmission line, you are measuring the entire system (cable and connectors) for faults. If you put the meter at the antenna you're just checking the antenna and not the transmission cable/line and connectors. If you do both then you can determine the difference between the two points and there is nothing wrong with doing both.
Wsak418
Thanks! Did both and got it all adjusted down to a 1.3 not bad. Getting 1.1 with a short lead from radio to antenna
