HELP! Audio problems
coggers
Cedartown, Ga.
my scanner feed for Polk County is connected but I have no sound. I have tried line in as well as mic inputs. Volume is turned up
Should metadata fields in OddcastV3 be empty?
richtidd
San Mateo, Ca
I guess you are saying the scanner headphone out is connected to the computer audio input.
You may need to select the input type in your computer audio settings or the sound card settings. Depending on what your set up is, you maybe using the mic input or a line input.
Oddcast should also detect the audio settings but you may need to manually select. This needs to be set for the correct input. Look at the Live Recording window in Oddcast.
What you are looking for is the right input setting on the computer & through Oddcast.
