Radioddity Help connecting to Radioddity GD77 CPS
GM4NSZ
Hi All,
I have been fighting with a used GD77 for some days now. So far, I have managed to get the radio to be seen by the laptop (Win 7 but not Win 10). I get the 'bong' when the radio is switched on and the USB 'Mouse DEMO' driver that others report is there. However, when I try to download the codeplug from the radio, using the Radioddity CPS, I get a message which says "Model Mismatch".
Looking at the info on the radio, I can find "Soft-Version v2.06.06" and Dev-Version HRC6000 V1.2.6" It also shows a last program date of June 2019.
I have tried all the versions of the CPS which are available on the Radioddity website with the same result - "Model Mismatch".
Has anyone any ideas what I might be doing wrong? I want to load OpenGD77 Firmware but am loath to do this until I know it works in its original form. Many thanks.
73
Mike - G8NSZ
GM4NSZ
Just go for OpenGD77. Dont bother with stock.
When I look at other information regarding software and firmware compatibilities I have a feeling that the CPS which is available on Radioddity is too 'modern' for the various programmes that are in this, seemingly, old GD77. The 'Must Read Tips' say: V2.6.2, V2.4.2 or others lower than V2.6.6----upgrade firstly to V2.6.6 or V2.6.8 or V3.0.6 then to V3.1.1 or higher versions. Mine is v2.06.06. It also says:
Firmware V3.0.6 is compatible with software V2.0.5. Firmware V3.1.1 and after V3.1.1 are compatible with software V3.1.1. I can't find a source of the lower firmware/CPS versions; they are not on the Radioddity site. My concern is whether OpenGD77 is compatible with my older stock firmware? The OpenGD77 instructions indicate that I need to: Unzip the donor firmware zip file, extract the 'GD-77 V4.3.6.sgl' file. This is well in advance of the firmware version that I guess must be on my radio as it has soft v2.06.06. I just have a concern that the radio will not understand what to do with v4.3.6 and die😬. Am I overthinking this?
dickie757
Wired
Out of range
No, they are over doing it with updates. I will look on my PC for any older stock firmware. I may have older OpenGD77 firmware that may play nice with your present setup, too.
