HELP!! I am buying a scanner! eastern NC
rett8799
Newport NC
I am in the process of buying a scanner radio, but have no idea what to buy. I live in newport NC and would like to catch the military aircraft as well as the local fire/police, etc... Any suggestions? I am not up to date on the whole trunking thing!! How do I know what to get for the area I live in?
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
The easiest way to narrow your choice of scanners is to determine "how" you want to monitor, and "who."
Are you content to monitor at home, in the comfort of a Lazyboy ? Or would you prefer to listen to the military aircraft while parked near the Cherry Point base ?
A base scanner, connected to an antenna mounted on the roof of the house, will enable you to monitor communications from a wide distance from your location. But, a handheld scanner can be taken to work, or any location that will get you closer to the action.
With an idea of whether you want a base / desktop scanner, or a handheld model, you need to decide who you want to listen to.
Newport / Carteret County is relatively easy to listen to. Most of the local public safety agencies are using VHF high band ... and the NCHP are currently on low band. Any scanner will cover those frequencies.
Not all scanners are capable of monitoring mil-air communications, though. You'd want a scanner capable of monitoring 138-144 MHz and 225-400 MHz in A.M. mode.
If you want to monitor the local military trunked system, you'd also need a scanner capable of monitoring UHF / 400 MHz trunking.
If you want to monitor the Jacksonville / Onslow County trunked system, you need a trunktracking scanner. Some of the talkgroups are reportedly digital, though, so a digital-capable trunktracker would be recommended.
Picking out a scanner gets complicated, huh ? Let the forum readers know who you want to monitor, and how, and we might be able to suggest particular scanners that fit your needs, although maybe not your budget : )
BTW - I got an enjoyable 50-cent tour of your fire department, and the National Weather Service facilities about 13 years ago. The FD still kept low band radios in a couple of the apparatus at that time. I also toured a local AM/FM station, just off Hwy 70. The AM side played Big Band music, but I believe they are no longer in operation.
Jeff Multer
Fort Mill, S.C.
rett8799
Newport NC
Handheld help?
I am really just looking for a handheld that I can listen to Carteret county fire/ems police, and nc highway patrol, and also cherry point when I have it in the car near the base. There are several on ebay and was looking at a RS Pro-93 or 94? Will this do?
jeffmulter
I would recommend the Pro 95 over the Pro 93 or Pro 94.
The Pro 95 is similar to the 94 ... both have more channels for programming than the Pro 93. I'm not sure what the inventory status of the Pro 95 is in the stores, or through Radio Shack Online, but you should be able to find the Pro 95 at a similar price "used" as the Pro 94.
The Radio Shack catalog still shows the Pro 94 and Pro 95 ... both at $150.
The Pro 95 is capable of both 800 and 400 MHz trunking. Although the mil-air band is not an advertised scanning range for the Pro 95, there is online freeware (shareware, really) available that allows you to extend the listening range of the scanner through the mil-air band. The only additional item you'd need is a programming cable, available through several sources for about $20.
New, the Pro 95 was probably one of the best scanner buys during this past Christmas season.
After the Pro 95, my next recommendation would be a Uniden BC250, although the price - even used - would likely be over $200. That price doesn't include software, which I always recommend.
Jeff
