Freescan: Help importing frequencies using freescan
Shaner19
Huntsville , AL
I have successfully programmed a Uniden 396XT and 325p2 scanners using the freescan software and importing from RR. But I don't see as many counties in the import wizzard of freescan as I do on the databases list on RR. How do I import those other counties too? I'm kinda new to this and any help is appreciated.
kma371
There are two different areas, one is to import trunked frequencies by county and one is to import conventional frequencies by county. Make sure you select the correct for whichever you are trying to download. That's probably why you see more on one than the other because you are only viewing about half.
