Sentinel: help in adding a frequency into Centenal
dave3825
Suffolk County NY
You can add a freq to a favorites list by reading the scanner into Sentinel, then edit the favorites list you want to add it, and then navigate to where you want it, and add it. The write back to the scanner.
KC7CKO
Olympia, WA
I have centenal software and I am trying to add a frequency that is not in the data base to a existing list of ones that are in the data base. How do I add in Centenal software
So my question regardless of my spelling is still the same. I cannot see the videos and would apreciate someone who is willing to write out how to. As a Blind person, watching a video is much different than having someone explain.
dave3825
Suffolk County NY
So you most likely use some sort of screen reader or similar. You said your trying to add a freq to a list, presumably a favorites list the you or someone created. If you are somewhat familiar with Sentinel, then it's pretty much what I described in post 3, or here.
If your not familiar with Sentinel, then see if you, or someone can get your favorites list exported from Sentinel, and zipped (compressed) and posted here in this thread with the freq you want added, and I am sure it can get done for you.
