Help LRRP
I3YBD
Hola everyone
Where can I find the instructions for use LRRP?
thanks , Maurizio
Forts
Mentor
Ontario, Canada
Start lrrp.exe, hit ? for a list of available keys/options. Please note that if you aren't seeing LRRP entries in the DSD+ Event Viewer then the LRRP app will be useless to you. It doesn't work with other 3rd party GPS platforms (neoNytro etc).
I3YBD
thanks Forts
It will verify if there traffic !!
Hello Maurizio
I3YBD
hi
where am I wrong?
This is what I see !!!!
73, Maurizio
racingfan360
>where am I wrong?
You're not doing anything wrong....as Forts has said, there isn't any Motorola GPS data to decode based on your screenshot: it's likely to be a 3rd party app.
If you look at the equivalent screenshot on this page you will see the GPS co-ordinates/speed/direction data gets decoded in the Event Log window, and it is this data that then gets used by the LRRP.exe to display on a map.
DSD+ Version 1.5 Released - rtl-sdr.com
No co-ords in the event log = no data for LRRP.exe to show on the map.
I3YBD
>where am I wrong?
Thanks for your answer
I do not understand what you mean the creenshot on this page?
and I do not know the 3rd party app?
If I understand you correctly if I do not receive a transmission from a GPS Motorola will not be shown on the map ??
Maurizio
racingfan360
ok, go to http://www.rtl-sdr.com/dsd-version-1-5-released/
There is a screenshot of a map: "DSD+ V1.5 LRRP GPS Display"
It also shows an DSD+ Event Log
This event log shows a decoded LRRP data in purple WITH GPS data (Tgt, Src, Co-ordinates, speed, direction data)
But your screenshot does show LRRP data but there is no this GPS data.
So this means there is either no GPS data being sent, or more likely, a non-Motorola GPS system mid being used. Again, if you see no co-ordinate data in the event log there will be no data for LRRP.exe to show on the map.
DSDPlus
It looks like compressed LRRP messages. DSD+ does not decode them.
I3YBD
ok, go to DSD+ Version 1.5 Released - rtl-sdr.com
Thanks!
Now I understand what you said !!!!!
Ciao Maurizio
I3YBD
I share with you !!!
Observing The DSD + Event Log
(LRRP; Tgt Src = 2,222,039 = 2,222,050), what are they?
