No affiliate scan programming is what you need. The only way you will get it is to learn the methods and do it yourself. Any authorized motorola deraler will laugh you right out the door of their shop most likely if you ask for programming such as this. Then again you may get lucky and find someone willing to do it for you. I suggest a few quality hours of reading over on
P25 Forums. Everything you need to know is there. Just make sure you read and read and read some more before asking any questions. They have a low tolorance of lazy folks unwilling to do the leg work themselves. Good luck.
I would agree with this. Most people don't know this but, no affiliate scan is a great way to monitor a trunk system with a Motorola. I've only been able to do this with P25 systems so your in luck. Essentially what you do is program all the trunk channels as conventional receive only personalities in the radio as its own zone. Make sure to include the control channels as well.
Then in your CPS under the ASTRO TALK GROUPS settings menu, enter in the talk groups in which you wish to monitor. I usually make each talk group a zone, but there is different ways to go about it.
Then back in your conventional personalities, you want to select the ASTRO tab and look at the squelch settings. Find the drop down menu and select "Selective Squelch". You have to excuse me if I'm not as detailed as I can be, as I don't have the CPS in front of me and I'm doing this by memory.
Then, you might get the red letter "I" on that tab and that's because you need to enable the talk group settings on another tab. (I'm sorry I can't remember the tab name, PM me if your need more information, I'll look at my codeplug to double check)
Then your going to want to create a scan list for your zone with every single trunk channel that you put into the conventional personalities. Make sure to include the same channel name to all scan list channels (I.E. Houston PD) Then you can program.
Listening is real simple, just select your talk group zone and push which ever button you programmed to scan and sit back and monitor the P25 system with the most fancy scanner you can have!
Like I said PM me with any questions you may have, I'm happy to help!
Good luck!
