Thanks! I will give it a try. Which program does everyone recommend? Seems a zillion out there and nothing I've been impressed with (yet)...
On my 396T (as opposed to the newer 396XT), I primarily use Uniden's UASD software. However, as some of the systems on the DFW area are beginning the rebanding process, and UASD has not been updated to allow for entry of the band plan needed for the systems that have finished this process, I'll probably have to use FreeScan or ARC396 (I have the Pro version). For the 396XT, I'm using FreeScan.
As you are a premium subscriber, you can make use of web imports from the database. That's available with FreeScan, BCTool, ProScan, & ARC396. ARC396 is available in two versions, basic & Pro. The biggest difference is that the pro version allows for recording & logging that the basic does not. ProScan (I've never used it, but may try it for my 396XT) also allows for recording. BCTool & FreeScan have many of the same features, but are freeware, though donations are appreciated by the authors.
ARC396 & ProScan can be downloaded for a free trial period of about 30 days, before you have to discontinue use or buy the program. FreeScan, BCTool, & Uniden's UASD are free anyway (you cannot do imports from the database with UASD). I would recommend trying the free programs first, use them for at least a week or two, and see if BCTool or FreeScan will meet your needs. If neither one quite suit you, then do a trial of ARC and/or ProScan.
