Would that not be the case for you in Halifax . To be sure you don't miss any of the city stuff , Police/ Fire / Amb. would you , should you, not be monitoring the tower closest to the center of the city.
It is infact the case, and I've tried with only the main site as you suggested scnnr, and it still seems to be the same, Analog works like a charm, but digital TGs are garbled/broken, or it misses them all together..I think Chris might be right, either there is something wrong with it, or its just not comparable to a 396T, for overall listening ..
Somone asked about antennas, I have 2 external antenna's, one is a Discone(from Ebay, Centerfire Antenna's) that is said to be tuned for 400-800MHz, and the other is a 1/4 wave Dipole, tuned to 118MHz roughly, for air band listening.. I also have a "long line" in my attick, which is actually what I have the 396T hooked up to most of the time, and even being inside my home, it still picks up better then the Pro 96 on the 2 externals, that have almost perfect line of site to the Halifax tower, I'm trying to monitor. The long line is basically just a 40 foot piece of copper soldered to a piece of Coax, to feed down to my scanner, it was something I rigged up my self.
I've tried the Pro 96 on all 3, plus the ducky it came with from RS, mounted near my ceiling in the same room as the scanner, using a 50 Ohm BNC cable I got at "The Sourse", oddly enough, the ducky seems to get just about the same as the externals, maybe even better, which makes no sense to me lol.
IDK, but maybe the Pro96 got zapped in the travel back to Canada from Texas, I sent it UPS with a bunch of other crap I got while there..maybe they used some radar on it to look inside, and that damaged it?? So many Variables, so little time
