Help Please-Pro 97
slim011
Hey all,
If someone could help me please I would be forever grateful. I have a Pro-97 scanner and I think it's an awesome scanner, but I'm sure that I am using only half of its functionality. The part that confuses the hell out of me is trunking. I understand the basics of how trunking works, but when it comes to programming the scanner I'm lost. If someone has an "idiots" guide, or some tips, tricks I would really appreciate it. I like to think that I'm "advanced" when it comes to electronics, gadgets, PC's, but I'll admit I have met my match with this scanner. And one more thing, I do have the usb data cable for it. I know scancat? was an application you could use with this scanner, does anyone know of anything else that works with it? Thanks in advance!!
KC4YIN
Kinston NC
Win 97 created by Don Starr is a great program. It has a 30 day trial and it's the one I use.
jrrob8
Roanoke, Va
Try this file, it helps and you can carry it with you.
  • PRO-97_2.pdf
slim011
So it looks like I'm not the only person having problems if there were cheat sheets out there lol, thanks for the replies guys, this looks alot easier now :)
slim011
Ok I have one more question if you guys wouldn't mind. I decided to just upgrade my RR.com account and let win97 do all the work for me. Now can I put trunked freqs and conventional freqs in the same bank? I seem to recall reading something that you cannot do it, but I just want to be 100% sure. For example I have bank 0 with the first 4 channels with a trunked system that I wanted. can I put conventional freqs in the rest of that bank now?
KC5EIB
Flower Mound, TX
Yes you can, I have done that in most of my banks
gmclam
Fair Oaks, CA
Doug is correct, plus, you "could" put 2 trunked systems in the same bank.
There are a lot of issues with doing this and it is not recommended. Both systems would have to be the same type and not have conflicting TGs, just to name two minor issues.
Certainly you can put conventional frequencies anywhere you like. The bank would need to be set to the mode of the trunked system in that bank.
