Help Please?
RobinBrady506
Hello
I just purchased a Radio Shack pro-2052 dual trunking scanner...
I am new to the trunking thing. I Do not know what I am supposed to put the frequencies under like ED, E2-800, E2-900 E2-HI E2-UHF ED E1.....I am in Orange county NY.. I am trying to add frequencies such as 04-127 .. I tried for a few hours to get it right tonight, and i am pulling my hair out.. My Other half is too in-patient to even bother helping me. If someone could explain this to me EASY i would appreciate it so MUCH!!! thanks!!
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Welcome to the forum Robin !
Set up your Pro-2052 radio up for EDACS trunking for your county.
To do this hold down the TRUNK button until it beeps twice.
Next, push BANK, TRUNK and the bank #'s will flash.
Press a # to select which bank you want.
Use your up or down arrows to find Ed , press E
A link for Orange County is here,choose the site that you wish to
monitor.
http://www.radioreference.com/modules.php?name=TRSDB&sid=841
The 04- # you quoted is actually a talk group and not a frequency.
Enter the trunk freq's but be sure to start at the first ch. in the bank.
Press E
To check if it is operating properly, hit SEARCH and your ID's
should start appearing.
Enjoy your radio.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Adding to comments by mciupa,
This data was collected quickly using Win96 and is a sample of site 5 on the link provided by mciupa plus your Id 04-127 and a few others.
Code:
Site005 Ch01     855.48750    EDACS      0.0
Site005 Ch02     858.73750    EDACS      0.0
Site005 Ch03     858.98750    EDACS      0.0
Site005 Ch04     859.73750    EDACS      0.0
Site005 Ch05       0.00000    EDACS      0.0
Site005 Ch06       0.00000    EDACS      0.0
Site005 Ch07       0.00000    EDACS      0.0
Site005 Ch08     851.33750    EDACS      0.0
Site005 Ch09     856.13750    EDACS      0.0
Site005 Ch10     857.13750    EDACS      0.0
Dispatch          04-121
Emergency         04-122
Detective 1       04-123
Detective 2       04-124
Administrati      04-125
TAC 1             04-126
TAC 2             04-127
If this example is used, you will need to enter the freqs in channel 1 through 4 then skip 5 through 7 then continue entering 8 through 10. This sequence is known as Logical Channel Number (LCN).
Whichever site you use, set it up as listed in the data on his link. You can only program one site per bank and use only sites which you can hear the noise of the control channel.
