wondering what software you are using, to program the scanner.
assuming you have already purchased the uniden USB-1 USB cable
I am using ARC-XT. It is quite easy to use. I also have FREESCAN installed as well,
( and it is FREE ! ) and it too is easy to use.
I downloaded the FREESCAN about a month before I purchased the radio and played with it.
you don't need the scanner for either program. when I was comfortable with Freescan, I went
ahead and purchased ARC-XT software and played with it before I even attempted to set up
the scanner. I had the scanner a couple of weeks before I ever messed with it. I made sure
I was comfortable with the software before turning on the radio.
