help Programming LTR type on a TRX-2
powerstar
Suffolk, VA.
I was trying to program my TRX-2 to the local hospital in Suffolk, VA. 23434 the EZ-Scan pulls the info , but it does not seam to be working. really needs some help.
hiegtx
Dallas, TX
Looking at that system in the database, it is an LTR system, but the LCNs are unconfirmed, and there are no talkgroups listed.
If you have imported that system, via E-Z Scan, go to the Trunked system tab in the software and look at the system.
Click on it to select
then, under the Site list, click on it's site.
Now, looking at the site, click on the tab labeled as Site Options.
Where you see "Automatically Adjust Home Repeaters", make sure that option is set to 'Yes' (the default, when first imported, is 'No'.
If you are getting a good signal, that should allow the scanner to monitor the system.
85849
Also, as there are no talkgroups, make sure that you have a Wildcard in the talkgroups, so that the scanner will stop on any active TGID.
