hdesign
- Joined
- Jul 6, 2005
- Messages
- 18
Hello,
For the longest time, I was using the PRO-97 and listening to the Gurnee Police/Fire/EMS
with great success. One day, the radio traffic started to become less and less. I figured
that Gurnee had switched to digital and I would need to upgrade to the PRO-96.
As of a few days ago, I picked up the PRO-96 and found a new world of radio traffic to
monitor but the Gurnee area (even with a side by side PRO-96 and PRO-97 operating
together) is still received the same.
I have the V1.4 loaded on this PRO-96 and I'm confused. Most of the same traffic from
Gurnee Police/Fire is running on the following frequency listings:
Gurnee 860.26250 CT 127.3 D
Gurnee 855.63750 CT 127.3 D <- Mostly coming from here
Fire 154.32500 CT 127.3 D
The fire channel is still bad, even with the addition of the better 800 MHz antenna from
anyone on the Fire/EMS channel but the dispatch is clear as I'm right by the tower.
I have learned that Gurnee has applied for Digital but they are now running with a request
to extend their installation, as stated on the FCC website.
Why is it taking so long and if this is now in operation or listed as active, why does it not
sound digital as the StarCom21 does?
I see listings for the Gurnee area to use the following MOT Rx:
NW Dist TRS 855.23750 MOT 0.0
NW Dist TRS 866.46250 MOT 0.0
NW Dist TRS 867.46250 MOT 0.0
NW Dist TRS 867.93750 MOT 0.0
I pulled this from the V-Folders section of the PRO-96 (listed as IL-MI-IN) and it matches
with what is being posted on the RR DB with an exact match.
Why does this cover the StarCom21 listings as stated here:
http://www.radioreference.com/apps/db/?sid=2324
108 Dch Lake (County Simulcast)
855.23750*
866.46250*
867.46250
867.93750*
868.98750
I've selected to use the following talkgroups:
IDNR Regio 01282
Illinois Sta 00000
unid hit o 17103
unid hit o 17092
unid hit o 16385
unid hit o 41268
MOT 3600 CC (Normal)
MOT 9600 CC (Normal)
These are listed in RR DB as (Lake or Waukegan)
Here are my test results for both local listings:
StarCom21 - Illinois -- 700/800 MHz (Statewide P25)
Receiving mostly Chicago and Oak Brook traffic
When I click on the Dch Lake (County Simulcast) listing and it pops the window for the
area coverage, I see it more than covers my area:
Latitude N 39.70718665682654
Logitude W -89.05517578125
Range 225 Miles
All traffic is digital and clear but not relative to my area and especially the Gurnee area.
Lake County Law/Goverment - 800 MHz
Receiving traffic from Gurnee, Waukegan, (up to Russell Road), Island Lake area, etc.
This sounds like the traffic I have been looking for with this area but the signal is mostly
filled with static. I've cleared this up with the 800 MHz antenna for this unit.
Am I missing something? Should I be using different talkgroups for the StarCom21 listings
to hear the new digital for Gurnee?
When I go through the descriptions for the talkgroups, I see "Zones" listed. Which zone
should I be looking for to cover this area and not listen to Oak Brook, Chicago, etc.?
Using Win96 v1.55
Thank you very much!
David
855.23750*
866.46250*
867.46250
867.93750*
868.98750
IDNR Regio 01282
Illinois Sta 00000
unid hit o 17103
unid hit o 17092
unid hit o 16385
unid hit o 41268
Range 225 Miles
Using Win96 v1.55
David
