Trying to install discriminator tap in pro 39 I have wired it several ways still no audio showing on mic jack.Im using double ended 3.5 cord with one end cut off.
Here is a thread on the Pro51
http://forums.radioreference.com/ge...lp-installing-discriminator-tap-pro-51-a.html
Oh ok. I see that now that I reread the post he made. Sorry.That is not me its someone who was helping me with scanner.
And you're feeding the signal to the right channel (ring)? Any particular reason why? Are you sure that the mic jack is stereo?Trying to install discriminator tap in pro 39 I have wired it several ways still no audio showing on mic jack.Im using double ended 3.5 cord with one end cut off.
It looks like your shield wire is grounded to the frame. I dont know but I dont think its supposed to be maybe someone else will chime in.
