Help with 2-tone programming Minitor 6
Purplegoat88
Hello all, I'm on 2 depts and trying to program switch A to silent scan both dispatch channels for both tone-outs. the 2-tone for the second agency is motorola QC-2 1530-670 so i assume i need to enter that as a USER tone setting. for some reason it isnt working. the only thing i can think of is that maybe the first channel squelch is set too high and is holding the other channel open. when monitoring that channel i get constant static at sq 3. dropping it to 2= no more static. I have been at this for a week to no avail as i can only test it when there is a call or pager test. please someone advise if my thought process could cause this issue. thanks in advance!
N5XPM
Texas
I think the first test would be to program a switch position with the 1530 670 combination and confirm that combination works as a stand alone. Once that works, maybe the scanning configuration can be figured out.
Purplegoat88
That makes sense. I have used that combination on my kenwood mobile for 2-tone and it does work properly. I’m 99% sure those are the correct tones as that’s the info I’ve gotten from multiple sources.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If it helps, those are Plectron tones. The precise numbers are 1530/672. The 670 that you have been using is within tolerance for some decoders. The Minitor VI might be a touch pickier.
Purplegoat88
I thought they were. The thing is they’re timed 1-3 so when I tried programming them as plectron they didn’t work.
n3obl
Ø
PA
Minitor VI has a setting for plectron tones.
Purplegoat88
Yes however if my research is correct the timing for plectron tones fast is 0.75, 1 seconds. the timing for our tone out is 1, 3 seconds. I can only assume they converted the plectron tones to a custom QC system.
SteveC0625
It’s common to see this in tone systems. Try setting the tone system to Motorola and then enter 1530/670. The software will change your entries a tiny bit. Don’t worry about that, the pager has +/- variance of a half percent or so.
If that doesn’t work PM for my email address. I’ll take a peek at your code plug.
n3obl
Ø
PA
Set it to plectron and enter the tones I'll bet it works.
Purplegoat88
I tried that first thinking it must be close enough but that didn’t work. I’m really thinking it might have been the squelch holding the pager on the other channel so it never heard the one monitoring these tones.
ramal121
Lots and lots of watts
Calif Whine Country
Possible. Do you have any switches set for monitor? You could check for squelch breaks as you walk around.
Purplegoat88
Yes. And when I select the working channel it opens to static. I dropped it down to 2 and it no longer does that But haven’t had any tone outs to check if it corrected it.
Purplegoat88
so set to user with the squelch changed still didnt work, im going to try motorola with the nearest tones selected (1513, 669) with the squelch corrected and see what happens
Ant9270
The Green Weenie
Do you have the correct bandwidth set? Ex: 12.5 or 25.0KhZ
Purplegoat88
im going to setup one channel to selective call for this tone set and see if it even goes off and hopefully i can go from there
SteveC0625
There’s an app for smartphones that will give you the frequencies of the tone pair. It also will decode MDC1200 in addition to QC tones from any manufacturer. That would certainly help verify the tones for you.
