ImperfectSense
- Joined
- May 30, 2009
- Messages
- 3
Hi, I'm a relatively new scanner user interested in listening to the activity at the Boeing plant in Everett, WA. According to the database here: Scanner Frequencies: Boeing Everett Plant Trunking System, Everett, Washington there are two control channels for this site. My scanner is a Pro-164, which has Control Channel Only programming, so I programmed in those two channels, set the bank as a Motorola trunked system, programmed in the talk groups, and started scanning. At first, everything seemed perfect, I even discovered some new talk groups not listed in the database, so I was confident everything was working... Until I noticed that I wasn't receiving all of the talk groups I should be, in fact only about half. Then I noticed that the first control channel, 851.66250, didn't show the T icon that indicates a trunking control channel. However, when I would manually listen to that channel, a large number of new talk group id's would be displayed, ones that I had never seen before. It shows a strong signal, but the highest "message decode success rate" I've seen has been 35%, as opposed to the other control channel which decodes 99%. I've tried putting it in it's own bank, in case there was a conflict between the two control channels, but nothing changed. Does anyone have any idea what might cause such a low decode success rate?
