BCD436HP/BCD536HP: Help with Discovery
HandiScratchy
Charlotte NC
462.7375 sounds like NXDN to me but I am driving and listening on a cheap laptop with even cheaper speakers.
Thanks that's what I thought as well. Let me know about the 460.200 that's the one I think is DMR. To me DMR is fast and hard modulation where the NXDN is a little slower with softer edges for lack of a better term.
Ubbe
Stockholm, Sweden
Yes, that 460.200 are DMR and a idle burst that doesn't get decoded by Uniden scanners. They always sound in only analog audio while being monitoring in All mode that handles both analog and digital. It's probably a too short data burst to have time to be synced and properly decoded. Perhaps Unidens new firmware with improved digital decode will make it respond quicker to DMR signals.
The other audio are NXDN.
/Ubbe
HandiScratchy
Charlotte NC
Thanks Ubbe. Unfortunately I had to cut the files down to 1 second to make the zip small enough to attach. The dmr goes on for several seconds. Does that change your assessment?
Ubbe
Stockholm, Sweden
If it's just a steady streams of zeros, you can hear the datasignal sound just the same thru the transmission, then the scanner will not decode it.
/Ubbe
