Help with DSD Plus .bat files
bobruzzo
W1AV
Cranston, Rhode Island
I am running DSD Plus Fastlane....registered user...Program has current update and running OK.....I originally started using this program in 2020 and still usiong my original .bat file configurations. I use an RTL-SDR dongle to monitor a couple P25 systems and a few NXDN and DMR systems. I need help with how my .bat files are configured.....according to my set up, in order to start the program I use 2 bat files...."1R.bat" and FMP24-CC.bat".....here is how they are set up:
The "1R.bat" file:
DSDPlus -r1 -T -E -O NUL -i20001 >1R-log.txt
The "FMP24-CC.bat" file:
FMP24 -rc -i0 -o20001 -P-0.0 -g28 -b-12.5 -f853.875
First thing is I don't want to RECORD so I put the "-O NUL" in my 1R.bat. I am not sure and don't remember what the other settings are doing.
In the "FMP24-CC.bat" file I have it set to start monitoring 853.875 which is a zone in the system I monitor. gain set for 28 and bandwidth set to 12.5. I don't know what those other commands are doing. I think I need to tweak these bat files to get better results. Again I am monitoring mainly a P25 simulcast system. I use an RTL-SDR dongle connected to an 800 mhz 7 element yagi. Sometimes I use the OMNI X antenna but the yagi is better. Computer is a 2016 HP Envoy 16GB RAM and a 1TB SSD.
I live close to some of the towers for this system so I point the yagi northwest, away from the strong signals and it seems to work very well.
Is there anything else I can tweak in these bat files? Also there are a bunch of files in the DSD Plus directory I don't need or use but not sure which ones I can safely delete. The folder getting too big. Attached is screen shot of the DSD plus folder......
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
The "1R.bat" file:
You can delete the .FM and .IQ files. If it were me I would leave everything else.
1R.bat
DSDPlus -r1 -T -E -O NUL -i20001 > 1R-log.txt
-r1 # keep # role is single-receiver control/rest/traffic channel decoder [-r1]
-T # defunct # handled in menu system now
-E # defunct # handled in menu system now
-O NUL # don't record DSDPlus.wav / DSDPlus.srt
-i20001 # keep # link ID to FMP24.exe
>1R-log.txt # event log -- can get large
FMP24-CC.bat
FMP24 -rc -i0 -o20001 -P -0.0 -g28 -b-12.5 -f853.875
-rc # keep # Role is trunk control/rest channel monitor
-i0 # keep # Use first available RTL SDR device [-i0]
-P<num> # keep # Frequency correction PPM value (-999.9-999.9) [-P0.0]
- you know the rest for FMP24
So keep everything in FMP24-CC.bat
And ditches -T -E in 1R.bat
Incidentally, if you open up a command prompt and navigate to the directory your DSDPlus is in:
dsdplus -h
fmp24 -h
Those will give you the commandline information (which is where i got much of what I posted above)
bobruzzo
W1AV
OK tghank
1R.bat
FMP24-CC.bat
dsdplus -h
fmp24 -h
Thank you, I will do those things.
mayidunk
The "1R.bat" file:
I noticed that the "FMP24-CC.bat" file is coded with the fourth and fifth arguments coded together, without a space between them. If you typed that into your post, then it's probably just a typo. However, if you copied the contents of the file into the clipboard, and pasted it into your post, it might be something to consider.
Just so you know, I don't have the first clue as to what you're doing, or what the software does, but after nearly 30 years of making mistakes like this, I guess I've developed an eye for it.
bobruzzo
W1AV
I double checked and there is a space in my original bat files.....i mighta copied them to post here with what looks like a very little or no space.
mayidunk
Check the 7th and 8th argument as well...
millam
Old Radio Guy
This .bat file may not be any use to you but I use it all the time. I mostly search and listen,
don't sit on a site very long. The recording part would have to be changed. I have another
.bat file that selects which site I won't to monitor and sets up the .bat file with the input and
frequency. Some of the commands were deleted in the newer versions, this works in ver 2.457.
Mil
@Echo off
title My SDR Menu
mode 70,45
color 2f
:home
cls
echo.
echo Select a SDR - Antenna
echo ================================================================
echo.
echo.
echo.
echo SDR Serial Number Antenna -i?
echo 1 Airspy 573064DC316D33C1 Outside -i1 first in FMPA.cfg
echo 2 Airspy 644064DC354A1DCD Outside -i2 second in FMPA.cfg
echo 3 RTL 00000009 None -i"00000009"
echo 4 RTL 00000001 Outside -i"00000001"
echo 5 SDRPlay 1710004020 None -i1
echo 6 Flt Aw 00000003 Outside -i"00000003"
echo 7 Airspy A74068C8306D3393 Outside -i3 third in FMPA.cfg
echo 8 Airspy A74068C837602F93 Outside -i4 fourth in FMPA.cfg
echo 9 EXIT
echo.
echo.
set /p sdrnum=---Enter the number for the SDR you want to use--
echo.
if "%sdrnum%"=="9" goto quit
set /p freq=---Enter the Frequency XXX.XXXX--
echo.
if "%sdrnum%"=="1" goto a1
if "%sdrnum%"=="2" goto a2
if "%sdrnum%"=="3" goto a3
if "%sdrnum%"=="4" goto a4
if "%sdrnum%"=="5" goto a5
if "%sdrnum%"=="6" goto a6
if "%sdrnum%"=="7" goto a7
if "%sdrnum%"=="8" goto a8
:quit
taskkill /f /im fmp24.exe >nul
taskkill /im fmpp.exe >nul
taskkill /im fmpa.exe >nul
taskkill /f /im dsdplus.exe >nul
exit
:a1
set a="-o1"
goto dsdfmpa1
:a2
set a="-o2"
goto dsdfmpa2
:a3
set a=-i"00000009"
goto dsdfmp24-1
:a4
set a=-i"00000001"
goto dsdfmp24-2
:a5
set a="-i1"
goto fmpp
:a6
set a=-i"00000003"
goto dsdfmp24-3
:a7
set a="-i3"
goto dsdfmpa3
:a8
set a="-i4"
goto dsdfmpa4
:dsdfmpa1
start CMD /c "FMPA %a% -o20030 -f%freq% -b7.6 -L9 -M9 -V9 >fmpa1-cc.log"
start CMD /c "DSDPlus -r1 -F1 -T -E -i20030 -o1L -v4 >CC1.log"
goto exit
:dsdfmpa2
start CMD /c "FMPA %a% -o20036 -f%freq% -b7.6 -L9 -M9 -V9 >fmpa2-cc.log"
start CMD /c "DSDPlus -r1 -F2 -e -T -E -Pwav -m1 -i20036 -o1R -v4 >CC2.log"
goto exit
:dsdfmpa3
start CMD /c "FMPA %a% -o20038 -f%freq% -b7.6 -L9 -M9 -V9 >fmpa3-cc.log"
start CMD /c "DSDPlus -r1 -F3 -e -T -E -Pmp3 -m1 -i20038 -o1L -v4 >CC3.log"
goto exit
:dsdfmpa4
start CMD /c "FMPA %a% -o20040 -f%freq% -b7.6 -L9 -M9 -V9 >fmpa4-cc.log"
start CMD /c "DSDPlus -r1 -F4 -e -T -E -Pmp3 -m1 -i20040 -o1R -v4 >CC4.log"
goto exit
:dsdfmp24-1
start CMD /c "FMP24 %a% -o20032 -f%freq% -b7.6 -g27.5"
start CMD /c "DSDPlus -F2 -r1 -e -T -E -Pmp3 -m1 -i20032 -o1R -OM >CC5.log"
goto exit
:dsdfmp24-2
start CMD /c "FMP24 %a% -o20034 -f%freq% -b7.6 -g27.5"
start CMD /c "DSDPlus -F3 -r1 -e -T -E -Pmp3 -m1 -i20034 -o1R -OM >CC6.log"
goto exit
:dsdfmp24-3
start CMD /c "FMP24 %a% -o20035 -f%freq% -b7.6 -P0.0 -g27.5"
start CMD /c "DSDPlus -F4 -r1 -e -T -E -Pmp3 -m1 -i20035 -o1R -OM >CC7.log"
goto exit
:fmpp
start FMPP -i1 -o20033 -f%freq% -L5 -b12.5
start DSDPlus -F6 -r1 -e -T -E -Pmp3 -m1 -i20033 -OM NUL
goto home
:exit
goto home
cg
Connecticut
That file seems VERY specific to your operation of multiple SDRs including Airspys (which need those individual serial numbers). Way overkill for the setup the original post references. Would be very confusing for someone that is looking for basic startup help
bobruzzo
W1AV
It reminds me of the old DOS batch files I used to make for colorful menus
