I posted info help before which ill paste at the bottom of this topic. but i fail to understand . If no ctts tone is used for ksp how does it work. for instance i live in harlan ky and hear harlan post and london post on 460.2375. if i dont put antenna pointing to london i get a lot of squelch sounds and interderance. so if it kills me how does a trooper in the next county say knox handle hearing harlan post and london post. how does a harlan trooper call harlan post and london not answer.because they say for example 977 to harlan so quick you really have to pay attention. How can i eliminate hearing london post and the interference attenuator does not work either. thanks andrew harlan ky.
Posted: Tue Apr 05, 2005 12:14 pm Post subject: i need
I live in harlan cnty ky and use a uniden bc785d digital scanner for state police frequencies. i use a grove scanner beam and can get a lot of london post which uses the same frequency of harlan post. if i turn the beam perfectly i can get 98% percent of londons traffic. but i really wish not to, however if i turn the beam or use other antennas i get the scratching and un-audible traffic. . i hope that their is a tone ctss or something that i can place in scanner and eliminate the london post.. does anyone know of a free or cheap software program i can use to find tone frequencies that simple to use. I have a uniden 895xlt but on digital freq ill need to be able to hear the signal to distinquish between harlan post or london. If thier is another way or if anyone already knows the tones i would greatly appreciate it. thanks andrew stoots
