Help with programming a BC245XLT on a computer
rjp3637
As a favor to a neighbor, I'm trying to program his BC245XLT. The problem is that I can't seem to get the scanner to communicate over the COM port.
I've tried WinScan and ScanControl and neither will find the scanner. Both come up with error messages that the scanner cannot be found or is not communicating.
I know that the com port is operating correctly as Win95 will operate properly with my Pro95 over the same com port.
I've set up the scanner as instructed in the BC users manual (Turning it on while holding the data key down). I've checked the baud rate settings on the radio and it is set to 9600 baud.
Anyone out there have any idea what I'm doing wrong?
Ray
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It's fairly simple - you only did 1/2 the work. You need to hold the 'remote' (E) key down until it beeps twice. A very tiny key symbol will appear in the lower right hand corner of the display. The scanner is now in remote mode.
73s and GL..Mike
rjp3637
Hi Mike,
Thanks for the tip, I've tried what you've suggested and still no joy, I don't get the two beeps, I do get the display "1 PCCON". It still refuses to connect....
Ray
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
rjp3637 said:
Hi Mike,
Ray
Turn the scanner on normally (let it scan, don't go into PCCON mode) and then hit the remote key as described. You will then be in REMOTE mode. The PCCON mode sets up the speed on the port to be used to communicate with the computer.
73s Mike
rjp3637
Thanks Mike,
That's what I was doing wrong, I was holding down the remote key while turning on the radio! Tried it out without hooking up to the radio and it seems to be behaving correctly now...
Ray
