Help with programming Madison County MCT System
kc9neq
Illinois
Or will the 396xt find the LNC if stopped on the control frequency while using the custom search feature?
VASCAR2
So Illinois
If you look at each frequency listed there is a small grey number next to each frequency. That is the logical channel number (LCN). When you enter put the frequency in the correct numerical order. 01 frequency first, 02. Every number might not be present but just put them in numerical order.
The first frequency listed is 06 in red which means the control channel. Just enter the lowest LCN numbered frequency first as it doesn’t have to be LCN 01. As long as these frequencies are entered in the order below I think it should work.
06 855.1375
07 856.1625
08 857.1625
09 858.1625
10 859.1625
kc9neq
Illinois
I use ARC XT Pro programming software but was trying to manually program it. Never programed that type of system before.
Thanks VASCAR2 for the info. I will try that order.
tvengr
Well Known Member
Baltimore County, MD
Give this file a try. Save the attached zipped file to your computer and extract. You can assign whichever system quick key to the site you would like. Open the extracted file with ARC-XT and Upload to Scanner.
  • Madison Transit.zip
Starcom21
IL /MO/Global DB Adm!n
FYI. The system is extremely boring and sometimes just hard to listen to. The conversations just aren't much to want to hear lol. Good luck though!
