Help with Radio
KF0SOP
I've been trying to do a radio test on my Yaesu FT-70DR, using the K0ECS repeater, and I can hear people talking, but I'm not sure they hear me. What can I do?
K4EET
Chaplain
Severn, Maryland, USA
Best thing to do is to say this:
“Good afternoon. This is Kilo Foxtrot Zero Sierra Oscar Papa. I am a new ham and I would appreciate a radio check. This is Kilo Foxtrot Zero Sierra Oscar Papa in Olathe, Kilo Foxtrot Zero Sierra Oscar Papa standing by.”
Say that when the repeater is idle / not being used. Don’t interrupt an ongoing conversation (QSO) for a radio check.
littona
Super Freq
Council Bluffs, IA
Do you hear the repeater respond after you unkey your radio? You should receive a short little bit of noise. If you're not hitting the repeater, then that would be your problem. Check the transmit frequency and ensure you're using the correct PL code. If the database is correct, your radio should be programmed as follows:
TX 144.87 MHz
RX 145.47 MHz
PL 151.4 Hz (analog)
Make sure the PL tone is on the transmit side, otherwise you'll never open the repeater. The repeater is listening for that PL tone and won't respond if it doesn't hear it.
Where are yo when you are testing?
A hand held radio in a poor location, like inside a home or car, can have a really hard time reaching a repeater. You may be getting just enough signal into the repeater to trigger it, but your audio may be so bad that they cannot understand you.
If you've double/triple checked your programming, go outside, or get much closer to the repeater and see if it helps.
KF0SOP
Ok! I've been in my house when I do it. It's weird, because I never had that problem with my Baofeng UV-5RM
KF0SOP
I tried outside, but it just goes through as static when I transmit. I contacted an operator via my Baofeng, and he reported that to me when I used my Yaesu. He said that if they are both on at the same time, there'll be interference because they are so close together, so that makes sense. But even when I'm on my Yaesu by itself, no signal gets through. Is there something I can do?
K4EET
Chaplain
What assets do you have?
  • Dummy Load
  • SWR/Wattmeter
  • Coax Jumper Cables
  • Different Antennas (Yagi, High Gain Whip, etc.)
  • Anything else?
You are going to need at least the first three items. Those three will come in handy for years to come. Let us know what you have. If you need suggestions on what to get, don’t hesitate to ask.
KF0SOP
Thanks! I actually don't have any of that yet. If you have suggestions, I'd really appreciate it!
RichM
Try transmitting simplex frequency 146.52 from your Yaesu to your UV5R programmed to receive the same. If it sounds static, it’s your radio, if it’s clear, it’s your programming.
K4EET
Chaplain
Above are a dummy load and SWR/Wattmeter. Not the best in the world but something that will not break the bank while being 100% compatible with your HTs. For an HF station, you will need some different/additional equipment to do the same.
The dummy load will screw onto the SWR/Wattmeter but you will need a flexible coax cable between the SWR/Wattmeter and the HT. You might also need a coax adapter if the HT’s antenna jacks are different to interface with the coax cable.
This will get you started. In the long run, you will probably need a much larger dummy load when you become HF capable. The SWR/Wattmeter above does not cover HF so you will need another meter for HF.
Let us know if you have any questions. Also, others may chime in with alternate choices. I tried to keep costs to a bare minimum. If I were to recommend nicer equipment with better quality and better performance, you could be looking at spending hundreds of dollars. Should you wish to go that route, myself or someone else will suggest the better equipment.
KF0SOP
Thanks, guys! You've all been so helpful! I have a friend who's a ham, so he's going to come by this week, so I'll see if he can help me with testing!
KF0SOP
I programmed them to the same frequency, and I managed to get a signal! Wasn't strong, but it was something!
K4EET
Chaplain
You said that the signal “wasn’t strong” — is that from the Baofeng to the Yaesu, from the Yaesu to the Baofeng, or in both directions? If both HTs are 25 feet or less apart, the received signal should be very strong at both HTs. Was that the case?
KF0SOP
It's when I receive on my Baofeng. I have them near each other so I can transmit on one and hear the other. Static comes through, but barely a voice signal. My squelch is off on both
