Help with Radius 1225 portable programming cable?
dontsleep33
I have an Icom OPC-478 portable Cable and I would like to know if I could use that to program The Radius with it.
Will it harm the radio giving it a try?
bezking
On the Road
It will not program the radius. If you try to force the connector you will damage the radio.
(Hey - it's my 800th post!)
dontsleep33
Actually,is what's inside the db9 plug the same as what's in both types of cable? I can just put a new connector on the other end if it is.
n2hbx
Lady Lake, FL
You need a programming stand to program the radio...looks similar to a desktop charger. Also a RIB box and a Motorola battery for the radio. If you try to program the radio with an aftermarket battery, It will not work, at least not with a Multiplier battery.
