Help with setting up
ProScan
Software Provider
Ontario, Calif.
Here's a video of it. I have audio turned down on the scanner
You have the audio control Recorder tab selected and not the Source Client tab. Change it then ensure the Input is set to URL.
Can you post a screenshot of the Audio Control Source Client tab.
ProScan
Software Provider
Ontario, Calif.
I remember seeing the URL somewhere but can't find it now.
The 1st video shows the sound card selected and not URL. You had it correct before as shown in post #9.
Do this
1. Disconnect the Source Client
2. Change the audio back to URL in the Audio Control Source Client tab
3. Click the URL Setup button.
3a. Use the auto detect button.
3b. if the scanner doesn't show in the list, enter in the scanner IP address.
mjbjr
Macon,Ga USA
So it's now working. But it's not registering on the screen of the computer.
ProScan
Software Provider
Ontario, Calif.
Do this
1. Go to the Comm. Port menu and ensure the URL is selected for the Port
2. Click the URL Setup button and see if the scanner IP is entered in. If not click the Auto Detect button and see if the scanner shows in the list.
3. See if the bytes TX and RX are incrementing and not showing any errors.
mjbjr
Macon,Ga USA
All seems to have been running well but I went to pull an archive but nothing was there for hours which is weird. So i restarted the pc and scanner to rule that out and cant find
""The 1st video shows the sound card selected and not URL. You had it correct before as shown in post #9.
Do this
3b. if the scanner doesn't show in the list, enter in the scanner IP address.""
mjbjr
Macon,Ga USA
UPDATE
Seems it was on another scanner type and therefore I couldn't find it.
