Sunray-Skip
- Joined
- May 24, 2023
- Messages
- 5
Here's the tower in question any help in ID'ing it would be great. Verticals are 1-1/4", approx 17-3/4" from outside edge to outside edge.
It has a mast pipe that is adjustable (see image below A), currently raised as far as it will go. This mast pipe has a square section clamped in the middle (see image below C), see close up 3rd image down. Is the mast pipe one piece with the clamp at image 3 clamped in the middle, or is this something that joins to pieces? I'm wanting to mount a VHF antenna on this mast pipe and raise it as high as possible, and if it's just clamped, slide it further down the mast pipe.
Any criticism or advice is welcome.
